Date/Time: Sun, 12 Jan 2025 13:42:49 +0000
time clock
View Count: 893
[2017-03-05 19:38:53] |
Don H - Posts: 31 |
Computer clock off by 500 seconds but when go to set option under date/time to select time set by server getting message says do not have required setting. Am sending message along for analysis.
[2017-03-05 20:13:06] |
You will need to run Sierra Chart with administrator level access. Refer to: Global Settings Menu: Set System Date-Time from Server (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
