Date/Time: Sun, 12 Jan 2025 13:35:47 +0000
Strategy DLL virus issue
View Count: 703
[2017-03-04 22:35:51] |
Johnny - Posts: 99 |
Hello, Avast antivirus recognizes the dll of a specific strategy as a virus (Threat: Win32: Evo-gen [Susp]). This happens with a specific strategy only. Is the file safe, or could it be a possible threat?
[2017-03-04 23:51:34] |
It is extremely unlikely there is a genuine issue and that this is a false positive. We would not be concerned with it. Also refer to this information here which is helpful on this subject: https://www.sierrachart.com/index.php?page=doc/SoftwareDownload.php#AntivirusSoftwareFlaggingInstaller Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
