Date/Time: Sun, 12 Jan 2025 13:52:26 +0000
Exporting Fib tools Data
View Count: 959
[2017-03-04 17:39:55] |
BenjaminR - Posts: 170 |
I've tried using the spreadsheet study export Fibonacci level data, but doesn't seem it will export data from the Price Retracement tool. Is there study or tool that can do this in Sierra Chart? The idea is to find Fibonacci clusters using several time frames, then use that data to manually mark zones on a primary chart. Thank you, Ben Date Time Of Last Edit: 2017-03-04 17:40:26
[2017-03-05 20:35:36] |
You will need to use ACSIL for this: Advanced Custom Study Interface and Language (ACSIL) This is the particular function to access the data: Using Drawing Tools From an Advanced Custom Study: sc.GetUserDrawnChartDrawing() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
