Date/Time: Sun, 12 Jan 2025 14:01:00 +0000
Study/Price overlay not working
View Count: 872
[2017-03-04 10:22:28]
User740709 - Posts: 153
I am trying to overlay my 5M chart with Swing High and Low Study from my 15M chart by using Study/Price Overlay study in the same chartbook but no matter what I try to do, the lines do not display.
Could you help, please?
Thanks.
Regards,
Hana
[2017-03-05 16:07:07]
What you are doing is inherently very difficult because there is not a direct correspondence between the chart bars of the two different time frames of the charts.
[2017-03-05 17:33:42]
OK, so it means that it is not really possible.
Is that correct? OK.
Thanks,
Hana
[2017-03-05 20:05:37]
No it is not possible.
[2017-03-06 00:29:30]
TechTrader - Posts: 116
Copy the following files to your Sierra Charts Data Folder.
Open the chartbook Swing High Swing Low.
This could give you something to work with.
Note:The spreadsheet file has been edited.
Date Time Of Last Edit: 2017-03-06 01:44:45
attachmentSwing High Swing Low.cht - Attached On 2017-03-06 00:25:02 UTC - Size: 70.51 KB - 354 views
attachmentSwing High Swing Low.StdyCollct - Attached On 2017-03-06 00:26:33 UTC - Size: 18.7 KB - 402 views
attachmentSwing High Swing Low.scss - Attached On 2017-03-06 00:56:27 UTC - Size: 44.52 KB - 394 views
[2017-03-06 01:31:22]
Thank you for the potential solution for them.
