Date/Time: Sun, 12 Jan 2025 15:16:56 +0000
DOM position qty and P/L colors
View Count: 808
[2017-03-03 21:41:39] |
12VMan - Posts: 45 |
I'm trying to change the background colors for the 3 fields in DOM that are under "Pos Qty @ Price." Which items should I select in Graphics Settings - Global to change these? Are they controlled individually or as a group?
[2017-03-03 23:42:39] |
Refer to: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM It is the four color settings starting with this one: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart Trade Window Position Long/Profit Background Color Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-07 23:38:28] |
Thank you. I'd really like to be able to see the first field (position qty) and hide or black out the 2 P/L fields. It doesn't appear to be possible as the color settings are for all 3 fields, correct?
[2017-03-08 05:27:01] |
You need to set this Chart Setting to Do Not Display: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#ProfitLossDisplay Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
