Date/Time: Sun, 12 Jan 2025 14:06:12 +0000
Divergence indicator
View Count: 1258
[2017-03-03 01:44:00] |
sellis67 - Posts: 105 |
I'm using the divergence detector but can't see any symbol or data which shows the divergence. I'm using the default settings. Please advise on how to properly use the indicator
[2017-03-03 01:47:07] |
We are actually doing some work on the Divergence Detector study. Please wait a few more days. The angle calculations need work. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-03 02:06:10] |
is there a different divergence indicator available until DD is ready?
[2017-03-03 02:16:55] |
No.
[2017-03-03 02:26:47] |
ok i'll check back early next week. cheers.
[2017-03-03 10:27:15] |
is the DD indicator going to include any of the following? regular divergence Reverse (hidden, continuation, trend, etc.) divergence Tick/price divergence slope divergence ribbon divergence positive reversal negative reversal under/over divergence multiple divergence |
[2017-03-03 14:10:21] |
It simply checks for a divergence with slope only. You need to understand how it works. It is documented here: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=382#Divergence_Detector Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-03 14:41:50] |
ok awesome. I can use a fast D 14/8 on a 3min chart for 4 other divergence types. yay. thx.
[2017-03-04 06:38:06] |
I can't figure out how to get my MACD to be a histogram. I really tried. I need it for divergence. How do I set it up? Thx
[2017-03-05 00:37:06] |
We have released prerelease 1526, which has the improvements to the Divergence Detector study. I can't figure out how to get my MACD to be a histogram.
Try using the "Bar" Subgraph >> Draw Style.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-05 00:37:24
[2017-03-05 01:49:58] |
the pre release does crazy things to the chart trader. 8 digit win/loss numbers.
[2017-03-05 03:02:07] |
We have an idea about this. Since you are using CTS this could potentially be an issue with the Tick Size and Price Display Format settings. Do not use the the Prerelease for now. Wait about a week. Do not ask us further about this until then. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-05 03:22:58] |
I think you forgot to write "please"....
[2017-03-05 04:35:23] |
Yes. Please wait.
[2017-03-05 05:09:34] |
Oh absolutely. All you had to say was please. ;) I'll check in with you in a couple weeks. Take care |
[2017-03-05 21:41:53] |
We have determined the reason for the problem. And we are releasing 1527 now which resolves the issue.
