Date/Time: Sun, 12 Jan 2025 13:44:00 +0000
CTS T4 pricing
View Count: 608
[2017-03-03 01:41:48] |
sellis67 - Posts: 105 |
I'm in the TopstepTrader combine which is sim based. When I get funding then I'm live trading. Is it possible to use the new pricing across both platforms?
[2017-03-03 01:52:00] |
You can use the new lower-priced connection model with CTS only for live trading.
