Date/Time: Sun, 12 Jan 2025 13:43:25 +0000
question on chart settings ?
View Count: 543
[2017-03-03 00:38:07] |
User20450 - Posts: 330 |
what is point of this feature , i just noticed it was new ? thanks
2017-03-02_19-36.jpg / V - Attached On 2017-03-03 00:37:21 UTC - Size: 36.71 KB - 209 views |
[2017-03-03 01:49:25] |
This limits the number of days of historical market depth data which is loaded into the chart. The lower the number, the less memory used and also the faster loading of chart data.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-03 01:50:01
