Date/Time: Sun, 12 Jan 2025 13:52:17 +0000
.twconfig (DOM order template) not holding settings
View Count: 721
[2017-03-02 15:41:23]
trader1 - Posts: 128
I have a DOM order configuration (.twconfig file) set up with a target and a trailing stop-limit move to BE after x amt of ticks. Every time I use a different configuration and I move back to that one it is changed to a regular stop and I have to reconfigure it. Can you tell me what is happening?
Thanks.
[2017-03-02 18:52:59]
Make sure that after you change the settings that you save them.
Refer to the instructions here:
http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#TradeWindowConfigurations
Date Time Of Last Edit: 2017-03-02 18:54:32
