Date/Time: Sun, 12 Jan 2025 19:03:50 +0000
function to retrieve the value of an index from the current index ?
View Count: 782
[2017-03-02 14:25:53]
User210074 - Posts: 63
Is there a function to retrieve the value of an index from the current index?
Example: I have a FESX graph. I want to retrieve the value of the ES in code.
Just an exemple to explain what i said at the top
/*in Dax Code ( x.cpp)*/
int A{1};
int B{0};
int C{sc.PersistVars->Integers[B]};
C=A;
/*in SP500 Code ( Y.cpp)*/
int Dax(int A){
the function to retrieve the value of the Dax (C in Dax)
-> return C;/*return the value of the Dax*/
main(){
int date{sc.BaseDateTimeIn[sc.Index].GetHour();};
int Dax(Date);/*Dax value*/
[2017-03-02 18:50:19]
To access data for another symbol using ACSIL, refer to:
http://www.sierrachart.com/index.php?page=doc/ACSILRefOtherTimeFrames.php
Also, the code you wrote is not valid C++.
[2017-03-07 18:38:30]
sc.PersistVars->Integers[0]
Is it possible to put a string, in the sc.PersistWar ?
Ex:
string Year = "2017";
sc.PersistVars->String[0]= Year;
I post that because the STRING is built with CHAR.
[2017-03-07 18:50:34]
Yes. But you need to use this function:
sc.GetPersistentSCString()
Reference:
http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html#scGetPersistentInt
[2017-03-08 22:35:11]
Is it possible to put a long long int in the sc.PersistWars ?
long long int A =201704031555001;/*15 number*/
long long int& Nombre = sc.PersisWars[0];
Nombre = A;
[2017-03-08 23:24:16]
Yes. Use sc.GetPersistentInt64()
sc.PersistVars is considered out of date. You should not be using that anymore.
Use these functions:
