Date/Time: Sun, 12 Jan 2025 15:06:47 +0000
Simultaneous connection to 2 different feeds and FXCM
View Count: 683
[2017-03-02 05:41:32]
User113734 - Posts: 60
Hi Sierra,
2 questions:
1. Is it possible to use SC Data - All services as my main feed to analyze spot FX charts, while somehow being able to enter trades via a live account connected to Sierra.
For example/ My automated strategy analyzes USD/JPY tick volume using numbers bar via SC Data - All services, but it must enter the trades via my LMAX live account, which would also be connected to Sierra. Possible? The reason I want to do this is because I find the volume analysis via SC Data - All services to be more accurate than LMAX exchange.
2. If I were to open up a live account to trade with FXCM, are there any plans in the foreseeable future to remove FXCM from Sierra or everything is business as usual despite the recent issues the broker had with the CFTC, etc?
Thanks.
[2017-03-02 19:09:37]
1. We have to test this. There are some settings to change which should make this work as you want.
2. FXCM will not be removed.
Date Time Of Last Edit: 2017-03-02 19:09:56
[2017-03-08 17:34:34]
We looked into this, and while Sierra Chart does have the underlying capability to make this work, it is not currently supported in the case of LMAX.
