Date/Time: Sun, 12 Jan 2025 14:06:51 +0000
not getting data real time
View Count: 574
[2017-03-01 14:16:25] |
User289304 - Posts: 1 |
I signed up for Pkg 5 yesterday, and I get static delayed data only, have I missed something?
[2017-03-01 16:38:11] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Also refer to: What is Included in the Free Trial?: What Data Is Real-Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
