Date/Time: Sun, 23 Feb 2025 02:16:42 +0000
[Locked] - How to use .cpp extension
View Count: 2037
[2017-03-01 11:42:26] |
User638836 - Posts: 8 |
Hello , Please ,when i open custom studies file ,there are files with .cpp extension in ACS_source, and when i choose one extension and try to open it ,it's open Notepad++ with a formula with .h extension !how to do for opening the studie in chart ! thank you |
[2017-03-01 18:01:20] |
Are you using Analysis >> New/Open Custom Studies File? Could you update to the latest prerelease following the instructions here: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Make sure you update to the prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-01 18:02:01
[2017-03-02 19:13:19] |
Yes,i used Analysis >> New/Open Custom Studies File
[2017-03-02 19:25:41] |
We see you have not updated to the Prerelease as instructed in post #2 above. However, what exactly do you mean by this?: , and when i choose one extension and try to open it
What you need to do is select a filename. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-02 19:25:43] |
[2017-03-03 08:58:06] |
Hello, I want to use the studies with .cpp extension in the chart. |
[2017-03-03 19:35:00] |
Are you still experiencing the problem with the latest version? We simply cannot reproduce the problem. When we select Analysis >> New/Open Custom Studies File and select an existing file name with a CPP extension or enter a new filename without any extension, the file is properly opened with a CPP extension. If you are having an issue we need you to explain the clear and precise steps that you are following. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-02-08 02:59:52] |
NIKROD - Posts: 4 |
Hello, i am also having the same problem. I followed all the instructions above, but when i select one of the Custom studies it opens it up with notepad and i can't see the chart.
[2021-02-08 03:33:43] |
Flipper_2 - Posts: 57 |
You don't open the .cpp files. First open a chart, then select, Analysis>Studies>Add Custom Studies>Sierra Chart Custom Studies and Examples And select which studies to apply to your chart with the "Add" button. |
[2021-02-08 08:35:22] |
Regarding post #8 follow the instructions here: How to Use an Advanced Custom Study or a Study Collection Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
