Date/Time: Sun, 12 Jan 2025 23:41:41 +0000
Volume on the price ladder
View Count: 1876
[2017-03-01 10:56:06]
User391949 - Posts: 14
Dear Sir/Madam,
The volume on my trade DOM is showing more lots being traded than every other person that I know and they all use the same data feed as me. Please could you let me know if there is any potential reason that this is the case so that I can fix it? Thank you!
Regards,
Guangyao
[2017-03-01 17:58:16]
Provide an image of the Trade DOM, by following these instructions:
[2017-03-17 10:42:05]
http://www.sierrachart.com/image.php?Image=1489747308540.png
[2017-03-17 10:51:55]
As per the above chart, my volume numbers are different from others that use sierra chart, and my VPOCs are sometimes different as well.
[2017-03-17 18:35:47]
This is what we see for 2017-03-17 for the June Bund and is definitely accurate:
http://www.sierrachart.com/image.php?Image=1489775720543.png
How does it compare to what you see for 2017-03-17.
Make sure this Input with the Volume by Price study is set to 1:
http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_TicksperVolumeBar (Ticks Per Volume Bar)
Date Time Of Last Edit: 2017-03-17 18:36:42
[2017-03-20 11:00:17]
http://www.sierrachart.com/image.php?Image=1490007482240.png
Please see the above screen print which shows my volumes traded at each price to be different from your correct ones. I have already the Volume by Price study set to 1.
Thanks.
[2017-03-20 17:22:11]
Previously you said this:
What we see in the chart image you posted is that the volumes are lower than what we show although we are using a different data feed. So what you are seeing compared to others, is more accurate since you see more volume.
For the most accurate data feed use the Sierra Chart Exchange Data Feed:
http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php
Also refer to:
http://www.sierrachart.com/index.php?page=doc/CQGTrading.php#SolvingMarketDataFeedProblems
[2017-03-20 20:44:31]
The comparison I made was with other people also using CQG data feed with Sierra Chart, and therefore it cannot be the case that my data was not accurate enough, as the same data feed should show the same data. I think that it may have something to do with my Sierra Chart settings. Please let me know what potential settings could have resulted in this.
[2017-03-20 22:43:22]
Make sure Sierra Chart is set for a tick by tick data configuration:
If you see more volume compared to others at a particular price level, then you have more complete volume data. This is what we are saying.
[2017-03-21 07:11:49]
But I was sent the correct data in a screen shot for the 27th of March by you and mine was different from that?
[2017-03-21 07:27:02]
Could it have something to do with the implied spread settings?
[2017-03-21 08:21:08]
Our chart and your chart are using two different data feeds. The Sierra Chart Exchange Data Feed for ours and CQG for yours.
There are no implied spread settings within Sierra Chart.
Date Time Of Last Edit: 2017-03-21 17:21:38
[2017-03-21 09:27:04]
All fixed now. Thank you!
