Date/Time: Sun, 12 Jan 2025 13:45:56 +0000
Free tick by tick EUR/USD forex data compatible with Sierra
View Count: 2420
[2017-03-01 08:35:46] |
Giorrgi - Posts: 3 |
Hey guys, The free data provided with the Sierra trial doesn't seem to be of a great quality for scalping (I guess it's OK for everything else). I checked out the compatible data formats. However, would anyone know of a free tick by tick data source that already has been tested as being compatible? Thanks |
[2017-03-01 09:14:10] |
Have a look at using LMAX: LMAX Trading Service However, the data is not free. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-03-01 09:34:59] |
Thank you for your kind and fast response. However, it seems to me that the LMAX data is the same as the historical data I currently see in Sierra? It says so on the page you linked to "Historical Daily Data: Provided through the Sierra Chart Historical Daily Data service.". -- Do you know whether Dukascopy data might work with. I attach a file that shows how this data looks in excel. |
Dukascopy data in excel.jpg / V - Attached On 2017-03-01 09:34:43 UTC - Size: 230.55 KB - 626 views |
[2017-03-01 17:25:20] |
However, it seems to me that the LMAX data is the same as the historical data I currently see in Sierra? The documentation in regards to Historical Daily data for LMAX is out of date and has been corrected. Historical Daily data when using LMAX is based on the LMAX data feed. You can use data in a text format. Here are instructions: http://www.sierrachart.com/index.php?page=doc/TextCSVDataFormat.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-03-01 17:26:07
