Date/Time: Sun, 12 Jan 2025 13:54:33 +0000
Can't see data for Nikkei (NK) on SC Data- All Services Data Service
View Count: 646
[2017-03-01 08:31:34] |
User514837 - Posts: 47 |
The title is my question. Is this by design or just an error?
[2017-03-01 09:15:23] |
That is not the correct symbol. You need to use this one: Description: Nikkei 225 Symbol: NY Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
