Date/Time: Sun, 12 Jan 2025 13:38:21 +0000
TPO charts not working
View Count: 1891
[2017-02-28 22:57:45]
User762435 - Posts: 7
I can't open TPO charts since this morning. Once opened the screen is totally black. You can see a screenshot attached to this post.
I will be really thankful for any your suggestions to solve this problem asap.
Andrea
attachmentTPO chart.pdf - Attached On 2017-02-28 22:54:52 UTC - Size: 188.1 KB - 473 views
[2017-03-01 00:07:13]
Remove all of the studies from the chart and add just the TPO Profile Chart study.
After that if there still is a problem post an image of the chart again following these instructions:
Date Time Of Last Edit: 2017-03-01 00:08:05
[2017-03-01 07:06:55]
http://www.sierrachart.com/image.php?Image=1488351885184.png
It still doesn't work. I attached a screenshot as requested, here you are, thanks a lot
[2017-03-01 08:17:21]
Could you send us your Chartbook. You can attach it following these instructions here:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
We will have a look at it and see what the problem is.
Date Time Of Last Edit: 2017-03-01 08:17:39
[2017-03-01 08:48:38]
I have sent he file by global setting
[2017-03-01 09:12:20]
That is not possible. We are not sure what you are referring to. Follow the instructions here to attach the Chartbook file:
[2017-03-01 12:20:33]
I have sent it
[2017-03-01 15:10:23]
I need an urgent answer, please
[2017-03-01 16:27:39]
The Chartbook is still not attached here.
Maybe you are reading the wrong instructions.
On this page,:
You need to go to the section titled "Attaching a File".
Another thing we want you to do is to follow the instructions here to reset the settings for the TPO Profile Chart study:
Chart Studies: Using Custom Default Study Settings (the name of the section is Resetting Default Study Settings For an Individual Study)
Also select Chart >> Reset Chart.
Date Time Of Last Edit: 2017-03-01 16:28:25
[2017-03-01 16:48:04]
ok, I have done
Private File
[2017-03-01 17:34:19]
There are two things that you need to do.
Open the Scale window for the chart following these instructions:
http://www.sierrachart.com/index.php?page=doc/Scaling.html#ScaleWindowMainPriceGraph
Set the Scale Range to "Automatic". Currently you have User Defined. That is the main problem. You should never be using a user-defined scale for the main price graph.
Set this Input with the TPO Profile Chart study to 20:
http://www.sierrachart.com/index.php?page=doc/StudiesReference/TimePriceOpportunityCharts.html#PriceIncrement (Letter/Block Price Increment in Ticks)
Date Time Of Last Edit: 2017-03-01 17:49:13
[2017-03-01 17:49:28]
Thank you very much, my platform is ok now.
Regards
Andrea
