Date/Time: Sun, 12 Jan 2025 13:45:33 +0000
Write bar data to file indicator update interval question
View Count: 679
[2017-02-28 17:54:21] |
User529859 - Posts: 18 |
I am using wirte bar data to file indicator to output csv file for my anylysis programe to read it. but often time Sierra chart show error message Chart: F.US.ENQH17 15 Min #4 | Study: Write Bar Data To File | Write Bar Data To File study: Error creating output data file: C:\SierraChart\Data\F.US.ENQH17.scid_BarData15m.txt | 2017-02-28 11:39:52 * I know it might be two programe access the file at same time might cause error. so my question is : is there any way can define output interval accoding to main chart time period? let's say 15 min chart will output every 15 mins. thanks rex. |
[2017-02-28 18:34:49] |
No, this cannot be controlled but the source code for the study is available and you can modify it to meet your requirements. Refer to: http://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html Although would have to look at the code again to verify this but we would think that there is only going to be an update whenever there is a new bar added to the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-28 23:46:45] |
thanks, I will look at it.
