Date/Time: Sun, 12 Jan 2025 14:06:12 +0000
Large Volume Indicator
View Count: 1466
[2017-02-27 21:40:00]
User80386 - Posts: 9
You can make a choice volume not only "from", but and "to"?
For example - from 100 to 200.
[2017-02-27 21:53:45]
This can be done through the use of the Volume Filtering on the chart itself:
http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#VolumeFilter
[2017-03-05 10:40:04]
I meant the other meaning.
On the same chart - the different indicators "Large Volume Indicator" with different volume.
For example, from 100 to 200 + from 200 to 500 and more then 500.
In order, different volumes have different types (Circle Based, Marker With text and Marker without text)
Date Time Of Last Edit: 2017-03-05 11:38:53
[2017-03-05 16:26:20]
This is not supported. You can only use one Large Volume Trade Indicator study on a chart.
You need to use separate charts
Date Time Of Last Edit: 2017-03-05 16:26:38
