Date/Time: Sun, 12 Jan 2025 14:04:30 +0000
YMH7
View Count: 627
[2017-02-27 17:04:11] |
User743109 - Posts: 3 |
Hi, I cannot run real YMH7 data, Sierra just has been downloaded historical data, with info: symbol is unknown, (in attached file). I reinstalled Sierra several times, NQH7 is ok. Thanks for help, Tom
[2017-02-27 18:21:48] |
We see you are using Transact. Refer to: http://www.sierrachart.com/index.php?page=doc/TransAct.php#Symbols Also we do not see a file attached. However, we do not think we need this at this time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
