Date/Time: Sun, 12 Jan 2025 13:46:37 +0000
SPX_volume_profil
View Count: 650
[2017-02-27 08:54:00] |
User850017 - Posts: 41 |
Hello, I use market SPX, sometimes ticker INX for daily volume profil studie. But market SPX is not tradingu, just index value. Values volume profil for this market is calculate from? Thank you |
[2017-02-27 09:00:29] |
You really need to use futures symbols for volume profiles. Not the cash market symbols. The cash market is not going to provide any useful volume profiles if there is not volume data or the volume data just indicates price updates.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-27 18:10:36
[2017-02-27 09:31:28] |
I need to know where SC volume studie calculate volume data when INX is cash market and has not volume data. What means this volume profil (attached files). Thank you
[2017-02-27 10:12:35] |
Actually, now that we look at an image of the chart, we were mistaken. It is reasonable to use a Volume Profile on a daily cash chart because some of those do contain actual volume data.
[2017-02-27 10:37:06] |
Ok, but volume data from what? When SPX (INX) is no trading, no volume..
[2017-02-27 16:03:21] |
I can see calculate volume for INX. This is volume for all SP500 stock and after use volume profil for every value of prices?
Attachment Deleted. |
[2017-02-27 18:11:52] |
Yes this is correct. You could also just add the standard Volume study to the chart to see the volume as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-27 18:12:18
