Date/Time: Sun, 12 Jan 2025 14:06:09 +0000
Inconsistent time flow
View Count: 630
[2017-02-27 02:01:19] |
User283641 - Posts: 4 |
Hi, my inernet download speed is approx 30mb/s but the time flow at te top of any chart is very inconsistent. There is usually gap several seconds so I am afraid that there is an interaption in my data feed flow. Thanks for assistance. |
[2017-02-27 02:21:13] |
You cannot make a determination based upon this method. What you describe does not sound unusual at this time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-27 02:30:52] |
It always happens during regular trading hours. So you saying its common and has nothing to do with data flow? Thanks |
[2017-02-27 04:20:00] |
It would be less common during normal trading hours for a very active market, but it is not a very reliable method to determine there is a problem. In the case of CQG, refer to this information here: CQG Trading Platform Service: Solving CQG Market Data Feed Problems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
