Date/Time: Sun, 12 Jan 2025 13:53:48 +0000
Show Cross-hair Values
View Count: 634
[2017-02-26 23:49:19] |
John Mc - Posts: 32 |
Is there a setting to control the display values along the top of a region to display the values associated with where the cross-hair is located? For example on an Hourly chart if I move the cross-hairs to 3 hours (bars) ago the values displayed at the top reflect the amount for the new (3 hour ago) bar. Thanx |
[2017-02-27 04:48:49] |
This is explained in detail in this section: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools We recommend using the "Compact Tool Values Window". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-27 14:36:49] |
Thanx, this helps.
