Date/Time: Sun, 12 Jan 2025 11:54:56 +0000
Volume - distinguishing w/ different colors based on candle
View Count: 973
[2017-02-24 18:43:24] |
12VMan - Posts: 45 |
Hello, I'm considering a move to Sierra Charts. I currently use a volume indicator (basic volume) where the volume bar is 1 color for a green candlestick and a different color for a red candlestick. Can this be done in Sierra Charts? I'd also like to be able to plot the moving average of the volume as well. Thank you! |
[2017-02-24 18:47:08] |
Yes this is all fully supported.
