Date/Time: Sun, 12 Jan 2025 13:45:42 +0000
Volume by Price
View Count: 898
[2017-02-24 15:35:21] |
User240686 - Posts: 86 |
have composite profile on far right of chart and a daily profile that displays on the right but to the left of the composite profile which is perfect. however I would like the daily profile to sit to the right of the current price as opposed to the bars sitting on top of the profile. Is there any way to do this?
[2017-02-24 18:14:39] |
Yes refer to: https://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#RightAligningVolProfilesWithSpaceOnRight Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-27 11:06:20] |
No all that does is move the profile to the extreme right and moves my composite profile to the left of the daily profile which is not what I want
[2017-02-27 11:13:13] |
Provide an image of the chart, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-27 12:00:54] |
http://www.sierrachart.com/image.php?Image=1488196745483.png so this is what it looks like but I would like to see if I can move the current bars to the left of the profile |
[2017-02-27 19:30:53] |
You just need to follow the instructions here as we linked to previously: https://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#RightAligningVolProfilesWithSpaceOnRight And for each of the Volume by Price studies on the chart, set this Input to Yes: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_AllowSideBySideProfilesRightSide And you need to adjust the order of the Volume by Price studies in the Studies to Graph list to control the order in which they are displayed on the right side: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#StudyDisplayOrder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-27 19:32:12
