Date/Time: Sun, 12 Jan 2025 13:38:57 +0000
Alerts with Crossovers
View Count: 2195
[2017-02-24 15:16:35] |
User28914 - Posts: 87 |
I'm trying to figure out how to setup this alert here's one I already use (=OR(CROSSOVER(SG1,-80),CROSSOVER(SG1,-80),CROSSOVER(SG1,80),CROSSOVER(SG1,80)), but I need to figure out how to set it up using the Woodies CCI Trend whenever SG1 ,SG2 , SG3, SG4 crosses above or below +/- a certain threshold. I,m not sure since there's a 1,2,3 and 4 SG. Thanks.
[2017-02-24 18:19:35] |
This is the formula you will need to use: =OR(CROSSOVER(SG1,VALUE1), CROSSOVER(SG2,VALUE2), CROSSOVER(SG3,VALUE3), CROSSOVER(SG4,VALUE4)) You need to change VALUE1 through VALUE4 to the "threshold" values that you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-27 16:22:35] |
I believe I figured out what needs to be done with CCI ,but need confirmation. I believe I need to setup 4 CCI Trend Indicators per chart with the proper alert inputs unless there's a way to combine all 4 in one CCI setup. Thanks
[2017-02-27 19:06:50] |
No, you do not need 4 instances of the CCI study if you use the formula given in post #2 above which uses the OR function.
