Date/Time: Sun, 12 Jan 2025 11:58:56 +0000
Max number of instances running for multiple monitors
View Count: 1247
[2017-02-24 11:20:02]
User584153 - Posts: 4
I want to use sierra with 6 monitors and have chartbooks on each one. How many instances can I run without a drop in performance?
Many thanks,
[2017-02-24 18:05:50]
This is something that you will have to make your own determination on. We do not know the answer to this. It depends upon the capabilities of your computer.
It certainly is reasonable to have six copies of Sierra Chart running. But you would want to have at least a quad core CPU. Intel Xeon processors also support more cores .
Date Time Of Last Edit: 2017-02-24 18:06:34
