Date/Time: Sun, 12 Jan 2025 11:49:59 +0000
BT Group FTSE
View Count: 645
[2017-02-24 10:21:01] |
KinsaleForex - Posts: 19 |
I'm getting a little confused reading through the documentation. What data services would I need to get a chart for BT Group which is on the FTSE? Cheers, Liam |
[2017-02-24 10:31:07] |
Did you need real-time data?
[2017-02-24 10:38:00] |
I'd say end of day / historical data would suffice. Thanks!
[2017-02-24 17:52:46] |
Refer to this page for the symbols for the London Stock Exchange: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks&ID=2#LSE Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
