Date/Time: Sun, 12 Jan 2025 11:44:21 +0000
How To Create A Changing Color SMA?
View Count: 622
[2017-02-23 19:34:45] |
User430373 - Posts: 1 |
Hi! I'm new to Sierra Charts and I'm watching all the tutorials videos I can find, I still haven't figured how to make a SMA which will color green when going up and red when going down. Perhaps it's already included in the indicators with another name? Thanks a lot |
[2017-02-24 04:09:13] |
This can be done by using the Auto coloring setting for study Subgraphs: Chart Studies: Subgraphs Tab >> Auto Coloring Refer to the instructions here to modify the Study Settings: Chart Studies: Adding/Modifying Chart Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
