Date/Time: Sun, 12 Jan 2025 11:50:21 +0000
Setting Breakeven
View Count: 1420
[2017-02-23 17:51:20] |
User960201 - Posts: 2 |
Hi, When I place my trades I am using my mouse to right click on the charts and selecting the order I wish to place. Currently when I press Breakeven, it is setting the BE price at entry price which I know is normal, I would like to set it as BE+1. Can you please tell me how I do this. Many Thanks Mark |
[2017-02-23 19:13:21] |
This can be set. Refer to the documentation here: http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#BreakEvenButton Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
