Date/Time: Sun, 12 Jan 2025 12:08:06 +0000
Rithmic
View Count: 592
[2017-02-23 17:00:16] |
User61993 - Posts: 9 |
Has rithmic datafeed server hold OCO? In website is written that "Server Managed OCO (Order Cancels Order): Yes" does it mean it has? Because my broker said to me that Rithmic didnť have server hold OCO, iˇm a little bit confused.
[2017-02-23 18:37:10] |
Yes server side OCO is supported with Rithmic. However, you need to enable this option: http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#UseServerSideOCO Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
