Date/Time: Sun, 12 Jan 2025 12:01:02 +0000
Reset Volume Profile at cash open
View Count: 851
[2017-02-23 14:42:57] |
nosast2 - Posts: 73 |
I would like to set the volume profile to be reseted at the cash open. Therefore I set the Start Time and the End Time of the cash session which works fine, when I open or reopen Sierrachart after the cash open. But having Sierra open before the cash open, the Profile is not reseted. Attached is a screenshot of my settings. The times are based on CET. Thanks in advance. Norman |
Bildschirmfoto 2017-02-23 um 15.41.59.png / V - Attached On 2017-02-23 14:42:20 UTC - Size: 89.6 KB - 330 views Attachment Deleted. |
[2017-02-23 21:46:02] |
We do see that the Volume Profile is not resetting and it should. We will solve this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
