Date/Time: Sun, 12 Jan 2025 11:51:39 +0000
ALERT SOUND PROBLEM
View Count: 1084
[2017-02-22 22:35:48]
raja - Posts: 20
I went to global settings and then general settings - alert tab
for alert 1. i chose a wav file.
but sierra plays a diff alert - not the one i selected
how to fix it
bala
[2017-02-23 04:19:16]
In the Global Settings >> General Settings window, do you hear the correct sound when you press the Test Sound button?
[2017-02-23 17:48:16]
raja - Posts: 20
yes i do
but the actual sound coming is prev sound
prior to change
bala
[2017-02-23 19:17:26]
Is there a study which is triggering this alert?
You need to set the correct Alert Number for that study alert. Refer to:
http://www.sierrachart.com/index.php?page=doc/StudyChartAlertsAndScanning.php#SelectingSound
