Date/Time: Sun, 12 Jan 2025 11:43:46 +0000
Sierra data feed and IB
View Count: 563
[2017-02-22 19:48:14] |
JamesP - Posts: 89 |
Hello, I'm in the process of using sierra's data feed instead of iqfeed. I think I have set everything up properly but I'm not seeing the m after the product symbol (ES). It seems I'm connected to tws but once the es chart data loads it doesn't continue to update. I have SC set in sim mode and tws to paper trading while I transition. Thanks in advance. |
[2017-02-22 20:41:05] |
You will need to connect to your Interactive brokers live trading account and make sure you use the correct futures symbol as listed in File >> Find Symbol.
