Date/Time: Sun, 12 Jan 2025 12:08:06 +0000
OCO_LIMIT_STOP_ORDER with attached target and stop orders
View Count: 827
[2017-02-21 22:22:45]
User953407 - Posts: 5
// Create an s_SCNewOrder object.
s_SCNewOrder NewOrder;
NewOrder.OrderQuantity = 1;
NewOrder.OrderType = SCT_ORDERTYPE_OCO_LIMIT_STOP;
NewOrder.Price1 = limitPrice;
NewOrder.Price2 = stopPrice;
NewOrder.TimeInForce = SCT_TIF_DAY;
//Specify a Target and a Stop. We are specifying one Target and one Stop, additional targets and stops can be specified as well.
NewOrder.Target1Offset = limitOrder_Target_Offset;
NewOrder.Target1Offset_2 = stopOrder_Target_Offset;
NewOrder.Stop1Offset = stopOrder_Stop_Offset;
NewOrder.Stop1Offset_2 = stopOrder_Stop_Offset;
I am specifying an order as above. When the order gets executed I get the IDs of the attached orders.
  if (Result > 0) //If there has been a successful order entry, then draw an arrow at the low of the bar.
   // Remember the order IDs for subsequent modification and cancellation
    Target1OrderID = NewOrder.Target1InternalOrderID;
    Stop1OrderID = NewOrder.Stop1InternalOrderID;
    Target2OrderID = NewOrder.Target1InternalOrderID_2;
    Stop2OrderID = NewOrder.Stop1InternalOrderID_2;
The when the position is not 0, I am checking which orders are live and I get all four of them!!!
by checking if sc.GetOrderByOrderID(Target1OrderID, ExistingOrder) != SCTRADING_ORDER_ERROR
How can this be true?
[2017-02-22 02:59:58]
The only way to know if the order is actually working and can fill is to use this function:
https://www.sierrachart.com/index.php?page=doc/ACSILTrading.html#IsWorkingOrderStatusNoChild
This is not the right method:
[2017-02-22 08:06:20]
In this case, could you please let me know what is the best way to find out which of the two orders in the SCT_ORDERTYPE_OCO_LIMIT_STOP has been executed?
Thanks a lot.
[2017-02-22 10:57:48]
You need to look at the OrderStatusCode of the order to see if the order has filled:
Automated Trading From an Advanced Custom Study: s_SCTradeOrder Structure Members
You can get the order details with this function:
Automated Trading From an Advanced Custom Study: sc.GetOrderByOrderID
[2017-02-22 11:58:00]
Marmany - Posts: 307
1)I am having an issue where a study is interpreting live attached orders as being scale in orders. My code has been adapted from that in tradingsystem.cpp and uses != SCTRADING_ORDER_ERROR.
In tradingsystem.cpp none of the examples contain the IsWorkingOrderStatusNoChild function. Is it a recent addition?
2) In the Manual the code example is:
//Order is considered working
if (IsWorkingOrderStatusNoChild(ExistingOrder.OrderStatusCode))
Should that be sc.IsWorking.......?
Please advise
[2017-02-22 18:24:09]
No. It just was never documented until recently.
No.
Date Time Of Last Edit: 2017-02-22 18:24:22
