Date/Time: Sun, 12 Jan 2025 12:36:48 +0000
Multiple user configuration settings
View Count: 645
[2017-02-21 21:44:50]
User751551 - Posts: 2
I use SC on my laptop with multiple monitors (1080) at my desk and the single laptop screen away from the desk. The laptop screen is ultra hi-res and I need to change font sizes, colors and layouts for readability. Is there a way to store and easily switch between these two configurations? Multiple user profile settings or something similar?
Ash
[2017-02-22 03:13:22]
No not really.
The best you can do is just switch between different Chartbooks which are configured differently as you require.
Color and font settings can be set on each individual chart within a Chartbook. Refer to:
Graphics Settings
[2017-02-22 03:24:11]
That should do the trick. Thank you.
