Date/Time: Sun, 12 Jan 2025 12:40:29 +0000
Lock / Unlock ACSIL User Drawn Drawing
View Count: 681
[2017-02-21 20:08:46] |
kas64h - Posts: 87 |
Hi, Is it possible to Lock ( or Unlock) an ACSIL user drawn drawing (AddAsUserDrawnDrawing set to 1), from within ACSIL code, so it's properties could still be accessed in the front end, but a user couldn't accidently move it. Many Thanks. |
[2017-02-22 03:45:37] |
This is not supported.
