Date/Time: Mon, 25 Nov 2024 01:49:54 +0000
Number bars volume percentage minimum
View Count: 888
[2017-02-21 19:02:06]
User879287 - Posts: 1
When setting the number bars background coloring method to "volume percentage" and only the 75% compare threshold used, is there a way to set a minimum value that I would like to see highlighted on the chart? Say I only want to see the 75% of the vol of a bar if that total is 400 contracts or more..Thanks
[2017-02-22 04:21:52]
No, this is not supported.
