Date/Time: Sun, 12 Jan 2025 13:04:42 +0000
TRade Window
View Count: 604
[2017-02-21 14:09:56] |
User39772 - Posts: 311 |
Hello, is it possible to add further quantity buttons to the attached trade window for charts. Currently i can oly use 5. another row with 5 again would be very helpful. |
[2017-02-21 17:46:47] |
No, this is not supported. But you can use different Trade Window configurations: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations Each configuration can use different quantities for those 5 buttons. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
