Date/Time: Sun, 12 Jan 2025 13:02:46 +0000
How to move a SC install to another PC
View Count: 634
[2017-02-21 10:52:43] |
User554317 - Posts: 59 |
I don't want to reinstall everything, customise my settings, chartbooks etc. Is there an easy way for me to 'move' a SC install to another PC? Thanks. |
[2017-02-21 17:22:10] |
Yes. Refer to help topic 15 here: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
