Date/Time: Sun, 12 Jan 2025 13:03:35 +0000
Cumulative Delta Bars for 13 lots orders.
View Count: 662
[2017-02-21 10:23:25] |
User252419 - Posts: 235 |
How can I create a Cumulative Delta Bars for 13 lots orders? Thank you, |
[2017-02-21 17:49:40] |
You need to set the Volume Filtering for the chart to only include trades that have a quantity of 13: Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-22 08:55:23] |
Can I have in the same chart a Cumulative Delta for 13 lots and a Cumulative Delta and Price of the product without filter? Thank you |
[2017-02-22 10:56:17] |
These will have to be separate charts.
