Date/Time: Sun, 12 Jan 2025 12:54:00 +0000
Not Displaying Certain Values of a Subgraph
View Count: 632
[2017-02-21 09:28:03] |
Pinger - Posts: 33 |
Hi I want test the value of Subgraph elements and not display them if they are outside a certain range, which will result in a discontinuous Subgraph. The valid values of my Subgraph can be both positive and negative so setting invalid values to 0 will not work. I'm thinking along the lines of setting invalid values to NAN. I'm tried this but none of my Subgraph is displayed. Is it possible to have a discontinuous Subgraph? Kind regards |
[2017-02-21 17:38:44] |
The only way to accomplish this is to set the values you do not want to display to 0 and then set the study Subgraph to not display 0 values: ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].DrawZeros Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
