Date/Time: Sun, 12 Jan 2025 13:03:26 +0000
display number wrong in Cumulative Sum of Study
View Count: 636
[2017-02-21 03:57:55]
The only way we are going to understand this is if you set each of the studies within that Chart Region into separate Chart Regions:
Chart Studies: Settings and Inputs Tab >> Chart Region
Do that and then post an image of the chart again following these instructions here:
[2017-02-21 17:19:52]
so what do I need to do to get the 16:00:00 true end of day value without it looking like the double bar in the screenshot I sent 5 mins ago?
You cannot.
so the question is why I need to add that last 1/100th of a second to get the true end of day value?
Effectively your question is why is the volume of this symbol study changing at 16:00:00.
It just is. That is the volume data based upon the exchange trade data. There is nothing we can do to change this.
Date Time Of Last Edit: 2017-02-21 17:21:16
