Date/Time: Sun, 12 Jan 2025 12:44:58 +0000
ACS - logging / avoid data on output
View Count: 1008
[2017-02-20 18:05:49] |
jizzary - Posts: 177 |
i'm looking to output a vector of values so i can copy it from log windows to excell sheet for that matter i'm looking to inhibit any additional output text added when i use the sc.AddMessageToLog() API is there anyway to achieve what i'm looking for ? |
[2017-02-20 18:55:17] |
The proper way to do this is to output the data to a text file and then read the text file in Excel. Refer to: http://www.cplusplus.com/reference/cstdio/ Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-20 20:45:31] |
i thought about this option - but you can add a parameter to your API to avoid all added text looks much more simple for me during development pls consider |
