Date/Time: Sun, 12 Jan 2025 12:39:32 +0000
no market depth in the DOM
View Count: 610
[2017-02-20 14:47:43] |
User297539 - Posts: 55 |
I have no market depth in the DOM and all my settings are gone.
20-02-2017 15-45-07.jpg / V - Attached On 2017-02-20 14:46:34 UTC - Size: 213.5 KB - 270 views 20-02-2017 15-37-57.jpg / V - Attached On 2017-02-20 14:46:48 UTC - Size: 66.15 KB - 277 views |
[2017-02-20 19:21:54] |
Update Sierra Chart following the instructions here: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate You then need to add the Bid Size and Ask Size columns. Refer to: http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#CustomizeChartDOMColumns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-20 19:27:42] |
Is it possible to save the DOM settings, and the other symbols Stored settings upload?
[2017-02-21 03:55:55] |
Yes, when you save the Charts and Trade DOMs as a Chartbook. Refer to:Chartbooks (Workspaces) and the other symbols Stored settings upload?
It is not clear what you are referring to.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-21 03:56:24
