Date/Time: Sun, 12 Jan 2025 13:06:05 +0000
Trial version no connection
View Count: 651
[2017-02-20 13:49:28] |
User755537 - Posts: 15 |
Hello, I have just subscribed for a trial version but I am not able to find in Global Settings >> Data/Trading service setting the option that would connect me. All what I see is (Not enabled on package). I have registered and active trading account with Interactive Brokers. Please, help. I want to test SC, if it gives me what I want. Thank you, Roman |
[2017-02-20 17:00:57] |
Sierra Chart - Max - Posts: 5778 |
1. Your account has been activated and/or reset. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit". 2. What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Sierra Chart Support |
[2017-02-20 18:26:08] |
Your account is now active. Follow the Interactive Brokers setup instructions here: http://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#SetupInstructions Let us know if you need more help Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
