Date/Time: Sun, 12 Jan 2025 12:59:46 +0000
CQG Disconnects
View Count: 639
[2017-02-20 09:12:07] |
User829216 - Posts: 15 |
Hello I seem to get frequent message log alerts http connections shut down and closed alerts....pls see attached file thx imageCQGminiDAX03.png / V - Size: 173.42 KB - 3 views - (Private) Date Time Of Last Edit: 2017-02-20 09:12:50
CQGminiDAX03.png / V - Attached On 2017-02-20 09:12:38 UTC - Size: 173.42 KB - 255 views |
[2017-02-20 09:47:23] |
You need to disable this option in Global Settings >> General Settings: General Settings Window: Periodically Set System Date-Time from Server (Global Settings >> General Settings >> General >> Update Intervals) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-20 10:01:09] |
ok thx for the fix
