Date/Time: Sun, 12 Jan 2025 12:50:56 +0000
not connecting
View Count: 645
[2017-02-20 08:55:56] |
User347737 - Posts: 9 |
Good morning, My Sierra wont connect this morning. Been fine for ages and worked Wednesday from the office but now won't. Keeps trying to reconnect and failing |
[2017-02-20 09:42:00] |
We see you are using CQG. Other users are having trouble connecting to CQG. CQG has been notified of this.
[2017-02-20 13:29:50] |
User394735 - Posts: 34 |
Any update on this?
[2017-02-20 17:46:47] |
Only that CQG is not aware of any problem. Which would indicate this is some Internet problem in your area. If you are still having trouble connecting post a copy of the Message Log again following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
