Date/Time: Sun, 12 Jan 2025 12:39:52 +0000
Several accounts management in one Sierra Chart program
View Count: 605
[2017-02-18 21:05:45] |
User517260 - Posts: 97 |
Hi! I need help - if I need to manage several accounts from my SierraChart - is it possible? Is it possible to use ASCIL programming for this purpose? Or I can organize it simply by another way? Thanks.
[2017-02-18 22:06:12] |
Yes it is possible if you are referring to trading accounts for the logged in Username with the Trading service you are using. Refer to: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
