Date/Time: Sun, 12 Jan 2025 13:05:59 +0000
Configure Button for Line tool - issue
View Count: 847
[2017-02-18 21:01:10] |
Marek F - Posts: 244 |
Steps: 1) In the Configure Button for the Line tool, options: - "Opaque Label Background" is disable. - "Copy Config Name To Text" is enable. 2) The Text of the Line tool is properly displayed. 3) Exit and Run the Sierra Chart. 4) Use the same Line tool config. 5) The Text of the Line tool is not properly displayed - there is a label background. And in the same Configure Button for the Line tool the option "Opaque Label Background" is enable. |
[2017-02-18 21:46:52] |
What you are referring to is the Global Settings >> Tool Configs >> Line Tool Configuration window. The Opaque Label Background option was not being saved. This will be solved in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-18 22:11:44] |
Exactly what i meant. Thank you.
[2017-02-18 22:19:02] |
There is no need to respond.
